UN-layers are gone after Field Maps 25.2.0, and still a bug in 25.2.2
236
Monday
SanneMikkelsen
It is not possible to see our layers coming from Utility Network datasets after the Field Maps 25.2.0 update, and that is still a problem in FM version 25.2.2. This was not an issue in past field maps versions and just started happening when the field maps app was updated.
No problems when I look at it in Map Viewer. All my non-UN-layers are working fine.
I have tested it in Field Maps 25.2.2. ArcGIS Enterprise 11.4. UN version 7.
Is anyone else experiencing the same?
@ColinLawrence this post is related to my reply in Error submitting after Field Maps 25.2.0 update
ColinLawrence
@SanneMikkelsen It looks like the layers are failing to load. Is there an error message when you tap on one of the Layers that failed? If so, can you share it with me? You can also check if there are any errors in the Troubleshooting logs. I apologize,  know I had you move this to another thread, but I would also suggest reaching out to Support (or your local distributor) to report this to them.
Regards,
Colin
SanneMikkelsen
Yes there is an errormessage (mostly danish, sorry!):
Kort:
MobilGIS/GAS 2.0
Lag:
Transmissionsrørledning
Domæne:
ArcGIS.ArcGISError
Kode:
Beskrivelse:
Handlingen kunne ikke udføres. (ArcGIS.ArcGISError fejl 1.)
 It looked a lot like the one in the other post. So I thought i would mention the thing with the UN-layers. I have already sent the problems to our local distributor, but at that time I had not seen a it was only the UN-layers...
ColinLawrence
My apologies @SanneMikkelsen , this does sound like the same issue mentioned in the other thread which is caused by duplicate layers. Can you confirm you have duplicate layers in your UN? We are still working on a fix for this bug.
I originally mentioned creating a new thread as I was thinking you had another issue with read-only layers, is that still the case?
Regards,
Colin
