Related Table/Inspection not working in Field Maps
4586
03-23-2022 09:34 AM
JosephHilliard94
Hi there,
I have created a feature layer and published to ArcGIS Online (and created a relationship class between point and table). When editing the point layer within a map in Field Maps, I cannot edit the inspection fields (related table) even though it allows me to add an inspection (the tick appears). Any ideas? I am pretty stumped and hopefully its an easy fix I am missing.
Have attached what's happening.
Thanks!
Joe
ChristinaHoddinott1
It sounds like you probably need to go into Field Maps on the web and create a form for the related table. I always forget to do that.
TeresaWhitney
Did you create a form on the related table?
ChristinaHoddinott1
KevinBurke
Hi @JosephHilliard94
Thank you for sharing that feedback.
Are you still running into the same issue today?
If so, would you be able to share the map/data with me to test on my end with it?
Thanks
-Kevin
by Anonymous User
Not applicable
Did you configure your pop up for the table in the web map?
