No Title After Search features
6873
14
01-04-2021 12:18 PM
vijaybadugu
I configured the Search Functionality in Web Map using "Find Location" and added Query layers. And When I search in ArcGIS Field Maps I am getting results as "No Title" Records. The layer Configured with Display Field and Configured proper title for Pop up using "Configure Pop up " in Web Map. Please find Attachment for more Info
jkarmon
I'm not having this issue on parent features (in my case a point hosted layer), but I AM having "No Title" issues (see second image) on related table records using a smart form. (The table has a title set in the pop-up's configuration - see first image).     This issue is occurring on Field Maps on both iOS and Android devices using version 21.2.0 last updated Apr 7, 2021.  Anyone else experiencing this?  Is there a workaround?TitleSet.JPG
Royce_Simpson
I'm having the same issue.  No matter where I set the title... either in the map viewer for the popup... and that's the title for each feature, not the generic title for the popup... or if I set the title in Field Maps, as @jkarmon is showing in her screen shots, I still get "no title".  In other words, I can't seem to do anything that make that not say "no title".
rge_esri
Hello,
Do those same records in your search result list show correct titles in Map Viewer?
rge_esri
Please make sure that the field chosen as the "Title" field has populated values. If the field value is blank/NaN, the title can be shown as "No Title".
JeremyBrown4
How do you choose what field is the "Title" field for each related record? I know you can set the Form Title of the related table, but I do not see where to chose the field for each record.
