Map Station Numbering and Offset in Field Maps for Linear Project
813
01-12-2024 01:30 PM
MatthewMcCracken
Hi There - I work on a lot of linear projects (Roads, Pipelines, Utilities) where we have an alignment with stationing.
Our Field Team requested if arcgis field maps could automatically calculate a station number for a point plus its offset from the alignment whenever a point is made. I know I can calculate all of this in Desktop, but is there a way to have it auto populate live in Field Maps?
Has anyone created something similar and found the capability in Field Maps?
Chris_S
I am not aware of a way to auto offset solely within Field Maps. You could look into an offset provider and see if that will meet your needs.
As far as automatically calculating a station number, you could create an attribute rule that generates a station number when a point is created within the station feature class.
Hope this helps.
