Location Tracking vs ArcGIS Tracker
2463
07-11-2023 04:37 PM
TimHayes3
I want to allow my Field Maps users to view their location. Meaning as they walk or drive a trail (line) will be visible that shows the route they used. I have enabled Location Tracking for Field Maps. I tested it successfully in Field Maps. But what is the difference if I use ArcGIS Tracker? is ArcGIS Tracker a different app than Field Maps?
LindsayRaabe_FPCWA
MVP Regular Contributor
Worth reading through this - it looks like Tracker functionality is being rolled into Field Maps.
Deprecation Notice for Explorer, Collector, and Tracker (esri.com)
Lindsay Raabe
GIS Officer
Forest Products Commission WA
LindsayRaabe_FPCWA
Lindsay Raabe
GIS Officer
AriannNassel1
Hello, I need to do something similar. Did you end up using Tracker or Fieldmaps? Thanks
LindsayRaabe_FPCWA
Tracker will eventually be fully replaced by FieldMaps so that's what I'd suggest you should use.
Lindsay Raabe
GIS Officer
