Layers in Field Maps Not Editable
16865
26
02-01-2021 09:04 AM
edatdcamm
I have created a map in AGOL with editable layers. However, even though I checked the "Make Available in Field Maps App" under the map settings, it opens in the Field Maps app as "read-only", and there are no edit options available for the individual layers. How can I make the map editable? FYI, the feature layers within the maps are already showing as editable in AGOL.
2 Solutions
KevinBurke
Hi @edatdcamm
I just wanted to follow-up to see if you'd been able to test what I suggested above by resaving the map to see if the ability to edit in Field Maps changes?
In general, when saving a web map that supports editing, certain keywords are added into the web map's JSON. One of the keywords being `Data Editing` that other apps including Field Maps use to allow the user to edit. The fact that that keyword wasn't written for that map despite the fact that you can edit in ArcGIS Online is the strange behavior. Therefore this is why I am suggesting resaving and disable/reenable editing in the map to trigger that keyword to get written as a test.
Thanks
-Kevin
KevinBurke
Hi @RobynSnookCCB
Thank you for that feedback. In the recent release of ArcGIS Field Maps v21.2 on both iOS and Android we addressed the issue where you needed to have `Use in ArcGIS Collector` enabled in order to edit in Field Maps. This should no longer be the case and you should be able to disable the use in Collector and retain the ability to edit in Field Maps.
- Are you working with the current release of Field Maps?
- Are you able to disable use in ArcGIS Collector and still edit in Field Maps if so?
Thanks
-Kevin
KevinBurke
Hi @edatdcamm
In the Web Map settings do you also have 'Use in ArcGIS Collector' enabled as well? Currently this is a requirement for editing in ArcGIS Field Maps.
Thank you
-Kevin
edatdcamm
Hello Kevin,
In my Web Map settings I do not have 'Use in ArcGIS Collector' showing as an option, only 'Use in Field Maps',
Ed Durbeck
RobynSnookCCB
New Contributor III
I was having the issue of where a map could be edited in Fields map on android but not on IOS. Everything was setup correctly. The issue was I didn't have "Use in ArcGIS Collector" enabled since we are moving over to field maps. This caused some inconvenience, it really should be highlighted when selecting these options.
KevinBurke
Hi @RobynSnookCCB
Thanks
-Kevin
RobynSnookCCB
New Contributor III
Hi Kevin,
You are right, I did not notice that the app required an update and it is working now disable from collector.
Thank you
KevinBurke
Hi @edatdcamm
Do you know if the ArcGIS Collector application has been blocked within your ArcGIS Online organization?
To check, see https://doc.arcgis.com/en/arcgis-online/administer/configure-security.htm#ESRI_SECTION1_2CBC381FFA65...
Thank you
-Kevin
edatdcamm
Hi Kevin,
The Collector app is not blocked (no apps are in our AGOL, of which I am the administrator). Of note is that the Collector app does not appear when clicking on the App Launcher icon in AGOL, but it does appear in the list of apps in the "Block apps" setting in the Security section of Organizational Settings.
Ed Durbeck
EDWARD F. DURBECK IV
Program Coordinator III
[cid:da1a9b02-b752-4eaa-a3ce-e53b045b27a5]
Division of Capital Asset Management & Maintenance
Office of Finance and Administration
One Ashburton Place, 15th Floor, Boston, MA 02108
www.mass.gov/dcamm
PHONE 617-727-4050
DIRECT 781-395-2588
KevinBurke
Hi @edatdcamm
The app launcher will not list Collector as it does not have a web app like Field Maps does. Therefore that is expected in that case.
In the original post, you mentioned opening the map in the Field Maps app. Just for clarification, are you referring to the mobile app or the web app?
Also if you go to Licenses, do you have a Field Apps section with the mobile apps listed?
Thank you
-Kevin
edatdcamm
Hi Kevin,
Yes, I am opening the map in the Field Maps mobile app. In the "Field Apps Bundle" in our AGOL Licenses section, both ArcGIS Field Maps and ArcGIS Collector are included, as well as three other apps,
Ed Durbeck
[cid:3a7f49e4-c3f1-44de-b643-0db59ec1b16a]
www.mass.gov/dcamm
PHONE 617-727-4050
DIRECT 781-395-2588
