I am trying to replicate Automatically Create Workforce assignments after an inspection. https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/automatically-create-workforce-a...
I am connecting using my ArcGIS online account and set the sub-domain to /<org-id>/arcgis/rest/services/Hydrant_Maintenance_Inspections/FeatureServer/0 Then select the Hydrant_Maintenance_Inspections layer and select adds. This module runs with no errors.
The Iterator runs with no errors
But on the Make an API Call I get ConnectionError ENOTFOUND: Service is temporarily unavailable.
Solved! Go to Solution.
@ErinAas3 The sub-domain should just be like "services{env}" in the connection properties. It sounds like you may have used the full URL instead of just the sub-domain. So it might be "services3", "services4", or just "services". I think once you fix that (with a new connection), it should work.
Hi Aaron,
I believe is it my connections, I have https://services(number).arcgis.com for the sub-domain. But I am still getting the same error on the next Field Map Module (Make API Call )with URL
Your connection should look like this when you configure it correctly with a subdomain:
For existing connections you can view them and it should look this:
Where it's {username} | {portalURL} | {federatedServerURL}
What does yours look like?
