Integromat/Field Maps/ Workforce Integration-ConnectionError
3583
03-01-2022 01:41 PM
ErinAas3
I am trying to replicate Automatically Create Workforce assignments after an inspection.  https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/automatically-create-workforce-a...
I am connecting using my ArcGIS online account and set the sub-domain to /<org-id>/arcgis/rest/services/Hydrant_Maintenance_Inspections/FeatureServer/0     Then select the Hydrant_Maintenance_Inspections layer and select adds.  This module runs with no errors.
The Iterator runs with no errors
But on the Make an API Call I get ConnectionError ENOTFOUND: Service is temporarily unavailable.
by Anonymous User
Not applicable
@ErinAas3   The sub-domain should just be like "services{env}" in the connection properties. It sounds like you may have used the full URL instead of just the sub-domain. So it might be "services3", "services4", or just "services". I think once you fix that (with a new connection), it should work.
by Anonymous User
Not applicable
ErinAas3
Hi Aaron,
I believe is it my connections, I have   https://services(number).arcgis.com for the sub-domain.  But I am still getting the same error on the next Field Map Module (Make API Call )with URL
by Anonymous User
Not applicable
Your connection should look like this when you configure it correctly with a subdomain:
For existing connections you can view them and it should look this:
Where it's {username} | {portalURL} | {federatedServerURL}
What does yours look like?
