How to show required field values in ArcGIS Field Maps
1102
05-10-2024 01:10 AM
anilbaindur
Hi All,
Please help me out with the solution I am looking for.
I have created a few Forms in Field Maps.
For Example:
I have two Fields, viz., Structures and Activities. Each field contains a different value.
Under Structures: Jackwell, WTP, ZBT, Intake well, Pumphouse, etc. (35 types).
Similarly, Activities like Site clearance, Excavation, Footing, Raft, PCC, Roof Slab, Approach Road, etc. (145 types).
Now I am looking a solution that when I select Jackwell then the related Activities should pop-up in the Field Maps App. But in the current scenario when I select Jackwell all the 145 different Activities are pop-up in the drop-down.
Since I am new to writing expressions some can help me out in writing the proper Arcade Expressions for getting the results as discussed above.
Field Maps Form
Field Maps Mobile App
When I select the JACKWELL under STURCTURES
All the ACTIVITES should not be shown. Only the related Activities should pop-up.
Please help me.
DavidSolari
MVP Regular Contributor
Would Contingent Values solve this issue for you?
HannesVogel
HannesVogel
for data capture you could also use Survey123 with cascading selects and use field maps only to show and not edit/create data
Jesuspisto
I am assuming "ACTIVITIES" is a domain in your database. If that is the case, I suggest building subdomains, that way you can have the relevant activities show up when you pick JACKWELL.
