How can I stream tracks offline?
3210
12
06-27-2024 01:53 PM
MikaylaLeishman
I'm trying to create an offline map in Field Maps that will allow our crew members to stream their location using a line layer (usually done when hitting the "Start Streaming" pop up on the online map/app. When I tried to make the regular layer they use to do so available offline, it said "The layer requires true curve client editing, which is not supported in Field Maps". Does anyone know a workaround to capture tracks offline on Field Maps?
Thanks!
Mikayla
ODWC_GIS
Why is my Point Observation layer showing me this error/warning message?
LindaWaters1
@LucasNeal  did you find the solution to this? My maps won't download offline but I have eliminated the error messages.
Debert
I'm receiving the same error message, while trying to check for offline compatibility.
It clearly states, "Errors in the content section must be resolved before the map can be enabled for offline use." And with that, offline stays disabled.
I haven't contacted support for assistance with this yet, but will give an update if/when that happens.
I am the GIS Lead for Iowa Regional Utilities Association.
Find me on Linkedin.
