Field Maps App - we want to Change a Field to make it Required
478
04-11-2022 03:13 PM
by Anonymous User
Not applicable
Hello,
We created a field map app, using ArcPRO and classic map viewer. We want to change the date to a required date field. I believe the only way to do this, is to go back to ArcPRO and make the change in ArcPRO. Is that correct?
Thank you,
Annette
by Anonymous User
Not applicable
If you are using the "smart forms" in Field Maps, you can just check a box to make it required.
Otherwise, yes you'd need to modify the feature class to make the field non-nullable and without any default values, then publish it.
by Anonymous User
Not applicable
