Field Maps App map list on iOS vs Android
1751
09-23-2024 10:55 AM
MikeOnzay
I primarily use an iOS device to view FM and I'm used to seeing a list of maps on my screen. A coworker's Android device (S24 Ultra - android v14) only shows folders instead of a list. Is this normal behavior? The Quick Reference page doesn't say or show anything about folders.
nspittlemeister_LCFPD
Hi Mike,
You are probably seeing the maps that you own in your content, where as a coworker likely doesn't own any maps, so they will see the folders or groups that they are a member of. See this section of the quick reference guide: https://doc.arcgis.com/en/field-maps/android/use-maps/quick-reference.htm#ESRI_SECTION1_9FF9489173C7....
Hope this helps.
Nick
Hi Mike,
Hope this helps.
Nick
MikeOnzay
I never noticed I had groups on my own device because my map list is so long! It all makes sense now.
