Field Map Designer Form "Editing is Disabled in the Field Settings" error, even though it is enabled
283
07-05-2024 04:24 PM
PatrickHellmann
I am working on a form in Field Maps Designer and there is a field that I cannot set to editable (data table field, not feature layer if that matters). Next to the editable box, it simply gives me the message "Editing is Disabled in The Field Settings". I don't understand why I am getting this error, as the field does have editing enabled, to the point that I am able to edit it on other webmaps, just not this one. Other fields on this layer work fine and can be edited. I've tried deleting and remaking the form, "Resetting to Source Layer Properties", and nothing works. I cannot make this field editable. Any ideas?
Patrick Hellmann
DanielFox1
Hi @PatrickHellmann
I see that the MeterID is hidden can you make it visible, does this open up the editing option?
