Exporting pictures with data from Field Map to an individual PDF
869
09-03-2024 08:45 AM
JulieShannon_DoR
Hello, I am trying to create a PDF of data collected at specific locations in Field Maps. My goal is to have the text data and the photo log exported together for each location to minimize office time after field work. The report is easily generated in survey 123 with pictures attached, however, the functionality of Field Maps will be better suited to my project needs. I know how to download the pictures in a way that isn't associated with the site, however merging them with text data after takes a significantly longer amount of time to complete. Is there a way I can add a code to a layout that will insert associated pictures for each site in a way similar to adding a dynamic Text box?
DougBrowning
MVP Esteemed Contributor
You can make a dummy 123 form linked to the Field Maps layer and then use all of its reporting tools.
More modern option would be a Dashboard.  We made a photo review dashboard and its so much easier then tracking down a pile of PDF files.  Been a huge hit.  Also nice to open original size images as PDF will down sample them.
You can also make something with Python and/or Data Driven pages in Pro.
Hope that helps
