Enable Search for Mobile Map Package in Field Maps
3053
06-01-2023 09:00 AM
vg11
Hello everyone, I am new to Field Maps so please speak to me like a noob in regards to this app. I recently shared my map as a mobile map package in order to have it downloadable in Field Maps for our field guys. I have found that I cannot search for our meter numbers or anything else I have in the map. I am able to search by address but that is it. I have looked around online for some answers and I have seen to press enter after searching something, that did not work. The other option may be to share a web map into Field Maps and then manage the offline areas, I tried this also - my map is very large and it is much more convenient (and would only work like this, the web map would cause the packaging to fail when trying to go offline) to share using a mobile map package. Is there any way I can enable the search in the mobile map package in Field Maps? I am using ArcGIS Pro 3.1.1, shared as a mobile map package to online, and downloaded on personal device in Field Maps app.
MarkBockenhauer
This post shows how to set up feature search in ArcGIS Pro, which will carry through to Mobile Map Packages that you create.  https://community.esri.com/t5/arcgis-field-maps-questions/how-to-configure-the-layer-to-be-fetched-i...
MarkBockenhauer
vg11
Thank you! Any chance you know the answer to this ?
