Displaying values instead of layer name when selecting a feature
1204
02-20-2023 07:42 AM
JohanKjetselberg
we are doing inventories of amongst others forest and we use old finds of certain plant, mosses etc as an extra information source in the field. However in these point-layers points often overlap and when you select a point you get a whole list of points, displayed with the layer name. So if we want to see the species name, we have to tap every single feature separately to get there. Is there a way to make fieldmaps display a certain field instead of only the layer name and coordinates?
Screenshot of fieldmaps app when i select a bunch of points. "Typiska Alunda" is the layer name, i would like to show values of one of the fields in the layer here.
Thanks!
RhettZufelt
MVP Notable Contributor
That is set in the Map Viewer popup config.
R_
