Default Values - Not Shown and Not Configurable Using Field Maps with Published Feature Layers from Enterprise GDB
18767
20
05-25-2022 05:41 PM
rsun_TQB
Hi All
Default Values are not shown and are not configurable using Field Maps with published feature layers directly from Enterprise GDB (not hosted service).
Is this normal? We are using ArcGIS Enterprise10.9.1.
It sucks... make Field Maps pretty much useless.
Any ways to bypass this?
Thanks a lot,
Reno
AbiDhakal
Hey Reno,
@rsun_TQB I'm struggling with my default values. the default values do not stick in Web Map or Field Map. Would you please be able to help me out. I'll really appreciate it.
Thank you,
Abi
AbiDhakal
@rsun_TQB
Here is my email address: [email protected]
AbiDhakal
Hey Keith,
It was very encouraging reading your post. I'm also trying to achieve a similar goal. Will it be possible to get your email contact so I can directly communicate with you as there are things I'm not understanding in your post. If the work around you suggest does the trick then it would help me big
Thank you for your consideration.
Abi
AaronCole1
This! 100%. Went back through the feature template in ArcGIS Pro, even with existing default values. Changed them. Changed them back. They turned gray. Saved. Republished. Problem solved. Thank you!
AbiDhakal
@tkeith1106
Hey Keith,
I'm struggling with the same issue and I'm not totally understanding the resolution you provide. would you please be able to help me out. Here is my email address: [email protected]
Thank you,
Abi
AbiDhakal
@tkeith1106 Thank you for your awesome help Keith. It seems to be working. I have not finished the project yet, but the initial tests were promising. I feel special receiving your email and having the opportunity to communicate with you.
Thank you,
Abi
AaronCole1
@AbiDhakal You have to make sure that your feature templates are going to propagate.  In the Attributes tab of the Template Properties window for the feature layer you are going to publish (Manage Templates > Properties > Attributes), if the little bar on the left side is blue, the default value will NOT propagate to Field Maps. You have to change the value, change it back, and then Save. Then it will show up gray and propagate through to the registered feature layer.
AbiDhakal
@AaronCole1  I will try and let you know. Thank you very much.
AbiDhakal
@AaronCole1 I'm able to make the feature attribute propagate. Thank you for your awesome help!
Abi
AaronCole1
Happy to help, but that was all @tkeith1106! Happy to hear you have it sorted!
