Default Values - Not Shown and Not Configurable Using Field Maps with Published Feature Layers from Enterprise GDB
18862
20
05-25-2022 05:41 PM
rsun_TQB
Hi All
Default Values are not shown and are not configurable using Field Maps with published feature layers directly from Enterprise GDB (not hosted service).
Is this normal? We are using ArcGIS Enterprise10.9.1.
It sucks... make Field Maps pretty much useless.
Any ways to bypass this?
Thanks a lot,
Reno
CWKAdmin
A small and obscure tweak in Pro did the trick!  Thank you for posting this.
I am publishing from an Exterprise Geodatabase on a stand-alone ArcGIS Server (10.9.1) using Pro 3.03.  In field Maps Designer, I could not set my default values as they were not showing up.  By toggling these in the manage templates panel in Pro and re-publishing, the defaults showed up in Field Maps Designer and are working in the Field Maps app.   Thank you!
