Data being deleted when using smart forms
614
07-19-2024 10:11 AM
GayleNeufeld
I created a smart form to update household information.  I use conditional visibility for most of the changes because the form is rather long.  The problem I'm having is that if the only changes I need to make are updating a phone number, I only have the phone number field show.  But by doing that it deletes the other information in the attribute table, such as the ID number, first and last names.  Is this normal behavior for smart forms?  Is there a way around this?  I don't want to have to show all of the fields I don't want data deleted from.
MitchellGrafstein
On each form in Field Maps (Designer), you should see "Form Settings" now on the bottom right.  (If you are using an older version of ArcGIS Enterprise, it is possible this might not show up.)  Within those settings, you will be able to check off "Preserve values when fields are hidden with conditional visibility rules" in order to do just that.
Mitchell Grafstein, Horticultural Inspector 1, NYS Dept. of Agriculture and Markets
GayleNeufeld
Yup, it was there.  Thank you, I can't believe I missed that!
MitchellGrafstein
It is a bit hidden off to the side and bottom.
You're welcome, glad you were able to find it and resolve the issue.
