/create conditional visibility statement for multiple feature types
2438
05-26-2021 05:34 AM
DirkPeterson2
I am trying to figure out the statement in Arcade for conditional visibility of certain attributes based on the type of feature being collected.  The types include dwellings (DWE), businesses or other structures (BOS) and defined outdoor areas (DOA).  I want to group certain attributes associated with buildings so in SQL its 'Type IN ('DWE', 'BOS')'.  There isn't an IN statement in Arcade, but there must be a way to do it, but I can't figure it out.
KenBuja
MVP Esteemed Contributor
Use the Includes function
var field= $feature.yourField;
var arr = ['DWE', 'BOS'];
Includes(arr, field); //returns true if field value is found in the array
KenBuja
DirkPeterson2
That worked!  I also came up with this.  I'm new to Arcade, so is this correct too?
KenBuja
That would work also, but as you add in more conditions, it can get unmanageable.
by Anonymous User
Not applicable
In the past (not sure on the current status) that function wasn't supported by the runtime so you needed to use IndexOf. Just an FYI to make sure you validate this in the mobile app too.
