Labels not displaying in Field Maps (from a mmpk)
1501
05-05-2021 12:29 AM
AileYG
I have previously created mobile map packages that display labels without problem in Field Maps. But the last one that I made simply won't show any labels.. and I can't find the reason.
Could it be because I used different classes and expresions to create the labels? I also used Label weight ranking and Maplex Label Engine.. is there something that is not supported in Field Maps when creating Labels with ArcGIS Pro?
Any other ideas/workarounds I could try to make them visible? Thanks
ChrisDunn1
Hi @AileYG - Maplex labeling should be supported. Are the labels that aren't displaying on points, lines, or polygons? If you are able to share the mmpk with us? That is probably the easiest way to identify the issue.
AileYG
Hi @ChrisDunn1 , the labels I was trying to display were on lines. In the end I managed to get them on the mmpk by using VBScript, (at least for one of the layers). I think the problem was that I was trying to get labels in two layers that were the same (just with different filters and symbology). I guess that is not supported...
