Changes to Feature Action settings not changing map in mobile app
3609
09-29-2022 09:09 AM
Sarah-CodyKnight
I'm trying to change Feature Action settings (adding copy shape and copy all options) for a map in Field Maps, but changes are not translating to the map in the mobile app. The map was made with just copy attributes originally and I cant add the other options.
The map uses offline areas, so I've tried updating the offline areas, recreating them, syncing the offline areas from within the mobile app, but nothing has worked
I'm using Field Maps from 22.3.1
Thanks for any help
DougMorgenthaler
Hi @Sarah-CodyKnight you should not need to update the offline areas for these changes to take effect.  Any new offline area downloaded should inherit the updated map settings; existing offline areas on the device would need to be removed/downloaded again.
DougMorgenthaler
Sarah-CodyKnight
That worked, thanks Doug.
