Calculated expressions in Field Maps
6852
11
03-24-2022 07:15 AM
jdelprete
Per the latest March ArcGIS Online update, we are now able to build calculated expressions, using Arcade, that automatically populate fields in Map Viewer.
I noticed that this new feature is available in the Field Maps web application as well. Though, after I add an expression to a layer's form and go over to the mobile application, the layer becomes un-collectable and states that "the form contains unsupported data."
Are there plans to support calculated expressions in Field Maps moving forward?
FionaRenton1
Ok thanks @Anonymous User . I see this in the documentation "Calculated expressions are not currently supported in ArcGIS Enterprise" but as there is an option in the web map field called "Calculated Expression" in our AGE so I thought it might work!
JanetSilb_Spike
I couldn't tell you @FionaRenton1 because I don't work in Enterprise. Perhaps @Anonymous User can answer.
