ArcGIS Field Maps: Manual Feature Entry and Autocapture coordinates?
587
04-10-2025 07:05 AM
renee_orie
Does anyone know how to get the xy coordinates to populate in the data table for manually entered features in ArcGIS Field Maps? I'm able to add features via Map Viewer when I'm not at the location but I don't know how for it to record the spatially connected coordinates in the attribute table? Any ideas?
fjramos
Try adding these fields in the "Pop-up" attribute expressions for desired feature layer.
X-Value
return Round(Geometry($feature).X, 2)
Y- Value
return Round(Geometry($feature).Y, 2)
fjramos
I forgot a couple steps:
The in the Pop-up "Field List" add the created expressions on "Select field"
Check the X, Y expressions
And they should be on your pop-up now
