Support symbol clustering in ArcGIS Field Maps
1116
11-21-2023 03:14 PM
ChristopherCounsell
MVP Regular Contributor
Points sitting on top of each other mean that field staff can't see geometrically coincident features.
e.g. 5 jobs loaded at one address, all sit on top of each other, field staff may prepare for or only complete one job. Not noticeable until a pop-up is selected and the panel shows 1-5.
Survey123 clusters the features together well.
3 Comments
abogedain
This is a very good idea, my team was debating today adjusting points manually to deal with an issue like this where 2 to upwards of 100 points come through on the same address point and when using a webmap other records from other datasets come up too if selection cannot be turned off for those datasets and it confuses unfamiliar users.
AndrewWillingale
I was surprised to find this functionality is missing after I setup the clustering symbology in a web map with a customer, and then found that Field Maps doesn't support it!
I didn't see any mention of this in the documentation.
SamerSlaiby
This would be helpful.
