Select by Attribute for Edit Multiple
1062
10-03-2025 01:01 PM
Status: Open
Labels (2)
RyanAglietti
I have a use case where users need to select all the valves that share a common project number so their inspection status' can all be set at once with the Edit Multiple feature. Our users are selecting too many features when trying to tap or lasso in an area with a high density of features and project numbers,
4 Comments
ColinLawrence
There is a limit of 50 features with the Edit Multiple tool in Field Maps. Are you requesting this limitation to be enhanced?
LindsayRaabe_FPCWA
@ColinLawrence to me it sounds more like the request is for a "Select by Attribute" function, though the max 50 features for Edit Multiple may also be a constraint worthy of a separate idea.
We are yet to implement any Edit Multiple functionality in our Field Maps due to it not honouring smart form functionality configured via Field Maps Designer.
ColinLawrence
@LindsayRaabe_FPCWA Thank you for the clarification!
I dont want to derail too much, but Edit Multiple now supports Smart Forms as of the 25.2 release of Field Maps.
LindsayRaabe_FPCWA
@ColinLawrence thanks, but it's still not quite developed enough for our use cases. The below screenshot shows how Edit Multiple differs from Edit Single. In this case, the smart form, should hide fields that are not intended to be edited, whilst aren't strictly read only. Also, it should auto calc the Authorised Officer, but doesn't.
