In regards to the Field Maps app, it would be great if you had the option to record a temporary trail showing the path that you have taken. I understand that this can be done using an editable layer but it would be simpler for projects that are for navigation only (not data capture) where its helpful to see where you have traveled but there is no need to retain the data beyond a specified time frame.
