Field Map Filter Attribute Feature
2605
6
09-15-2021 09:54 AM
DavidPineda
It would be great if we were able to filter based on an attribute within the field maps app (i.e. populate the map with inspections still needed to be done or certain trees).
6 Comments
by Anonymous User
DougMorgenthaler
SarahSaint-Ruth
LindsayWithers1
Just saw this changed to implemented (nice!) - when will the functionality be available in the (iPhone) Field Maps app?
SarahSaint-Ruth
Hi @LindsayWithers1 - this can be enabled today when using ArcGIS Online and available from ArcGIS Enterprise 11.1 and later. You configure this functionality for users in the field using Field Maps Designer. The help is available here on how to set this up: https://doc.arcgis.com/en/field-maps/android/help/configure-the-map.htm#ESRI_SECTION2_D4A1D89377A341...
