ArcGIS Field Maps - True Navigation Feature
6595
9
09-08-2023 01:40 PM
Status: Open
EricBushee
It would be nice to have a true navigation feature as part of Field Maps. I don't mean routing or driving directions, but the ability to select a location, and have the app guide you to the target location while on foot (e.g. a sample location, monitoring well, etc.). Many of us came from using Trimble devices in the field, and while we are more than happy to move past that outdated TerraSync software, at least it did have a navigation feature.
In Field Maps, the closest we have (I think) is the compass feature when you select a point, showing the distance and bearing to that point. But those tiny red numbers are so small they are almost unreadable in the field. They must be the smallest text in the entire app. In lieu of a separate navigation feature, just making the distance and bearing larger and the main focus on the screen after hitting compass would help.
Besides enlarging the distance and bearing to be readable, a navigation feature could also employ an audio alert when you are within a certain distance of the target feature. This is something many of us also got used to with Trimble's navigation.
9 Comments
NiallJohnson
I often upload proposed locations to Field Maps that field staff navigate to using the "Compass" tool.  Having something a little more robust than the "Compass" tool would be great add.
JonHoch
I second the idea of updating the field navigation ability of Field Maps. It would be great if it was more similar to a handheld Garmin device where you can select between North Up and Track Up and always show which way you are pointing.
My Apple device doesn't show a heading icon unless I Compass to the point then it shows the blue direction cone but it is always up as it defaults to Track Up with the map spinning. I much prefer in most cases North Up with an arrow showing which way I am facing and if I need to navigate to a point that it would show a line to point while staying in North Up mode.
My associate is on a Google device and their location icon at least shows an arrow when they start moving on the main view but also locks into Track Up when using Compass to navigate.
To reiterate it would be nice to just show current heading at all times for orientation/navigation and allow the selection of North Up or Track Up.
mathis2308
I would like to use the Field Maps app to navigate back to existing soil sampling points in a field.  This is difficult with the current Field Maps app.  Therefore, we are still using the handheld Garmin units to navigate to our points.  Being able to see the distance and bearing at all times would be a game changer especically when walking across a 90 acre field.  The Google Maps and Apple Maps directions options are useless when not traveling on a road network.
ChristineSeidel
Yep, ditto.  I have a new sampling crew of interns every year that must navigate back to the same sampling stations.  Please add the previously proposed suggestions to assist with navigation while using Field Maps.
ChristineSeidel
...I guess one work around would be to create a geofence around each sampling point?  Once the field worker is within X feet of the sampling point, they'd get a message saying it's now OK to sample.
EmmaWhite5
I agree with the proposed navigation feature. I am working with my team to change over to Field Maps from another data collection software that we have used for the last few years. A navigation feature is needed by our users so having this option would help massively with the switch over.
ZachEdwards_WDSGIS
Agreed. This feature could be improved. It's not ideal to have to tap on the feature, then the ellipses, then compass every time!
HassanBasagic1
Keeping the hope alive on this one! Improving compass navigation would boost this app. Right now, I switch apps to navigate which means exporting a custom map and switching apps in the field.  Having size ~4 font for direction and distance in the field is comical. I'd recommend at least size 12 font and then try testing in direct sun or while stumbling through steep rainforest.
JesseClous
It is amazing that this feature is not built in.  Stake out seems to be ignored in the Field Map GPS collection experience.  It was one feature folks are used to having available using Trimble products.  ESRI, please address the stake out and navigation features in field maps.  Trimble Terraflex is a good example of applicable navigation tools.
