Add button to allow user to recreate selected offline area in Field Maps
548
05-17-2026 09:41 PM
Status: Open
Labels (2)
LindsayRaabe_FPCWA
MVP Regular Contributor
In Field Maps, if a user needs to redownload a map area for offline use, they currently need to manually remove the offline area, either find the offline area for download or define it themselves (our standard workflow) and download the map.
Idea: Add a button to each offline area in Field Maps that allows the user to recreate the offline area from scratch (not just sync datasets within the offline area).
Use Case: Streamline and simplify the data management for end users within the Field Maps app. Removes the need to manually remove maps, and then select or redefine (navigate to desired area) for each map. This can be quite time consuming when multiple offline areas across multiple maps are in use as you need to wait for each map to download before proceeding to the next one.
2 Comments
Debert
@LindsayRaabe_FPCWA This can also be done on the Admin side in Map > Settings > Manage Offline Areas. Just another option for you..
LindsayRaabe_FPCWA
Thanks  for the tip but unfortunatley for us it's not useful as all our offline area maps are ad-hoc, user defined areas, meaning the tools that are built into Field Maps Designer for predetermined offline areas are not relevant.
