Add a filter widget to ArcGIS Field Maps
38151
82
03-03-2021 06:50 AM
Status: In Product Plan
Rose_Geater
Add a configurable filter widget to ArcGIS Field Maps, much like the filter widget in Web AppBuilder.
ArcGIS Field Maps is commonly used where users collect additional information on, or collect a related record against an existing feature. It would be really useful to be able to filter between different attributes on those layers, e.g. for priority points. Symbolising according to the feature works only when a few distinct attributes need highlighting. For anything more, different field maps need to be created with the different filters set as default. This can lead to having to manage, maintain and download multiple maps. If the user could filter on attributes of a layer from a single map this would be really useful.
82 Comments
GayleNeufeld
@TomMagdaleno  It only works on text fields or fields with domains.  I had to change several of our integer fields to text fields so I could use it.  I'm hoping that Esri continues to improve filtering and makes it so it works on any field.  The majority of what I need to filter on in the field is ID numbers.
LindsayRaabe_FPCWA
I tried this out yesterday for the first time only to discover that integers weren't an option. Made it useless in that scenario, but could still be useful in others in its current format. Seems a bit short sighted.
DavinShokes1
Like others have mentioned, the filtering is very limited at the moment I don't think this idea cant be considered implemented until we can:
Filter all field types including GUID for people needing to filter by related record.
Filter by more than "Field = X" and "Field is null". We need all the filters that exist across the esri platform:
  • does or doesn't contain a user input value
  • does or doesn't include multiple existing values
  • Is Not Null
  • Complex date filtering (within last 24hrs, before specific date, date range, etc.)
I'm hopeful we can use filtering in Field maps in the future. However, it is not useful without date and number fields being filterable.
Thanks.
ArmstKP
Yes, we need to filter not only on text fields, but also numeric fields.  I do not want to create new fields that convert numeric fields to text fields, run a scheduled model or an attribute rule and manage another field, just so I can filter in Fields Maps.....
Jan_Pieterden_Boer
Yes please. This will make working with the field maps app a lot more pleasant. I like a way with preset filter options for the enduser.
FaithSJohnson
How can you easily find the filtered results? Other than seeing them in the map or by searching for something in a searchable field that you know will be in the filtered results? Is there any way to view the items in a list or table?
Our features are small short lines, and they are difficult to see when zoomed out on the map, especially with so many other layers in the map. Well -- and we are filtering on multiple layers, etc. It's just hard to see the filtered results. In ArcGIS Online, I would open up the table.
JTLancer
Looking for ability to filter by numeric values as well as select more than a single value to filter by.
PeterHearns_Canada
I am looking to filter numerical values using the usual operations (greater than, less than, between) as well as being able to filter more than 2000 unique values.  Being able to use a "Contains" rather than having a drop down list would help.
LaurentSavoy1
@ChristopherCounsell
I was wondering if Esri plans to roll out a date range filter in production, similar to what QFIELD offers.
My team works rotating shifts from 6:00–18:00 and 18:00–06:00.
Our operators need to quickly view the data collected during the previous shift (and sometimes a bit earlier as well).
Unfortunately, I currently need to rely on another application to work efficiently. Without this update, I can’t really use Field Maps for our workflow.
Please keep me posted if this feature is planned—it would completely change my workflow and make things much easier for all of our users.
LindsayRaabe_FPCWA
OFFICIAL
Another great use case. Could you create a separeate layer in the meantime using a view of the layer with a pre-defined filter (something like features created in the last X hours)?
