load shapefile but can not host feature layer
1595
09-09-2021 07:07 PM
YanSong
I'm trying to host/publish a feature layer using the shapefiles. however, the shapefile loaded without problem. I can't publish the feature layer. Please see the error message below.
I have been host some of the layers for a while, but somehow the connection broke today, not sure if the website change something.
Please help!! thank you so much!
David_Brooks
MVP Regular Contributor
@YanSong can you share a copy of your Shapefile? If not, are you able to load it into an ArcGIS Pro,File geodatabase, and if it fails, you may get a better error log as to why.
Also, running Check and Repair Geometry tools to check for invalid geometries.
Chances are, you have an invalid field or an invalid geometry.
David
..Maps with no limits..
YanSong
I can load the shapefile without a problem. but I can't publish the layer
