I'm trying to host/publish a feature layer using the shapefiles. however, the shapefile loaded without problem. I can't publish the feature layer. Please see the error message below.
I have been host some of the layers for a while, but somehow the connection broke today, not sure if the website change something.
Please help!! thank you so much!
@YanSong can you share a copy of your Shapefile? If not, are you able to load it into an ArcGIS Pro,File geodatabase, and if it fails, you may get a better error log as to why.
Also, running Check and Repair Geometry tools to check for invalid geometries.
Chances are, you have an invalid field or an invalid geometry.
I can load the shapefile without a problem. but I can't publish the layer
