SearchByDistance on Joined Table
749
09-07-2011 03:35 PM
CollinGrove2
I joined a .dbf attribute table to a File GDB Feature Class, and want to do a spatial search. It works just fine on the FGDB Feature Class, by itself, without joining. However, when I join a table to it, and do a SearchByDistance, I get the error:
Details: Cannot project to null coordinate system
Parameter name: newCoordinateSystem
Anybody have any ideas? The error definitely comes from the SearchByDistance method...
AndreiIvanov
Your joined table is likely without projection. Set projection, and it should be fine.
CollinGrove2
What am I setting the projection to? It's just a spreadsheet table that I've saved to a .dbf. Do I need to just set it to the same projection as the FGDB Feature Class?
