KML change updates for LineStrings and Polygons don't work
5620
04-02-2014 12:00 PM
KennethTriplett
I am using a NetworkLink to dynamically update a map.  So far, I am only able to get Point coordinates to change properly.  I need to be able to update the coordinates of a LineString as well as a Polygon.
Create and Delete updates work fine, but the Change does not.  Here is my "Change" kml.  I've ensured that the targetHref and the targetId are both correct.
Any ideas?  Does ArcGIS Explorer support updating things other than points?
Any help would be appreciated.
<?xml version="1.0" encoding="UTF-8"?>
<kml xmlns="http://www.opengis.net/kml/2.2">
   <NetworkLinkControl>
      <cookie>cookie=CookieFrom2</cookie>
      <linkName>Enable Updates</linkName>
      <Update>
         <targetHref>http://192.168.128.208:7003/MoveEmptyTrackList.kml</targetHref>
         <Change>
            <LineString targetId="MTG_Track_01_01">
               <coordinates>
                  -90.88,35.00,363 -89.64,34.58,363
               </coordinates>
            </LineString>
        </Change>
      </Update>
   </NetworkLinkControl>
</kml>
JoeMetzidis
yes we do support "Change" with lines and polygons.
Please provide the Kml file you are changing and we will investigate.
KennethTriplett
Here are the files:
The Network Link:
  <Document id="ET">
    <name>ET</name>
   <visibility>1</visibility>
    <NetworkLink id="Tracks">
      <name>Tracks</name>
      <Link>
        <href>http://192.168.128.208:7003/EmptyTrackList.kml</href>
      </Link>
    </NetworkLink>
    <NetworkLink id="Updates">
      <name>Dynamic Updater</name>
      <Link>
        <href>http://192.168.128.208:7003/MoveUpdater.kml</href>
          <refreshMode>onInterval</refreshMode>
          <refreshInterval>30</refreshInterval>
      </Link>
    </NetworkLink>
  </Document>
</kml>
EmptyTrackList.kml
  <Document id="TrackList">
    <name>All The Lines</name>
  </Document>
</kml>
The first time, the MoveUpdater.kml file is:
      <Update>
         <targetHref>http://192.168.128.208:7003/EmptyTrackList.kml</targetHref>
         <Create>
            <Document targetId="TrackList">
               <Document id="LinesDoc">
                  <name>Lines</name>
               </Document>
            </Document>
            <Document targetId="LinesDoc">
               <Placemark id="Track01">
                  <name>Track 01</name>
                  <open>1</open>
                  <MultiGeometry id="MTGTrack01">
                     <LineString id="MTGTrack0101">
                        <coordinates>
                           -88.8,35.4,363
                           -89.6,34.5,363
                        </coordinates>
                     </LineString>
                  </MultiGeometry>
               </Placemark>
            </Document>
         </Create>
      </Update>
</kml>
After the refresh period, when ArcGIS Explorer refreshes the MoveUpdater.kml file, it retrieves this:
      <Update>
         <Change>
            <LineString targetId="MTGTrack0101">
               <coordinates>
                  -90.8,35.0,363
                  -89.6,34.5,363
               </coordinates>
            </LineString>
         </Change>
      </Update>
</kml>
The coordinates of the LineString do not update.  There appears to be a very brief flash as if ArcGIS Explorer is trying to bring up a popup box, but it goes away before any text is visible.  Any help figuring out why it does not update would be appreciated.
KennethTriplett
Did anyone investigate this issue, and is there any resolution?  The problem with lineStrings and polygons is still present.  It works properly in Google Earth.
