I am using a NetworkLink to dynamically update a map. So far, I am only able to get Point coordinates to change properly. I need to be able to update the coordinates of a LineString as well as a Polygon.
Create and Delete updates work fine, but the Change does not. Here is my "Change" kml. I've ensured that the targetHref and the targetId are both correct.
Any ideas? Does ArcGIS Explorer support updating things other than points? Any help would be appreciated.
The coordinates of the LineString do not update. There appears to be a very brief flash as if ArcGIS Explorer is trying to bring up a popup box, but it goes away before any text is visible. Any help figuring out why it does not update would be appreciated.
Did anyone investigate this issue, and is there any resolution? The problem with lineStrings and polygons is still present. It works properly in Google Earth.
