Hello all,
Trying to pull images dynamically from a URL at which they are hosted. I have given each map point an ID in the attribute table which corresponds to the ending of the URL for the required image.
For example: point has customID of 1.
I am using the dynamic expression: "www.examplesite.com/wp-content/uploads/date1/date2/" + {ID} + ".jpg"
Expression should pull from www.examplesite.com/wp-content/uploads/date1/date2/1.jpg.
No images are appearing.
To check it wasn't my expression at fault, I set the dynamic expression to just be a string pointing directly to an image (the same image should, then, be applied to all sites) but still no luck.
When I drag the spot in the Experience where the image should be to the URL bar of my browser, it points to: https://experience.arcgis.com/001/experience/www.examplesite.com/wp-content/uploads/2021/02/1.jpg. So, the URL is being parsed/created correctly but is being appended to an Esri AGOL URL for some reason.
Any advice would be greatly appreciated!
Mason
P.S. I also tried directly uploading an image to AGOL, but that link just points to an AWS server which would still face the same problem as described above.
