Workarounds for sending multiple polygons to Survey123 through Experience Builder
2054
04-29-2024 09:05 AM
hsummers_scf
Hello!
I am new to Experience Builder and still somewhat new to Survey123. I am trying to build a workflow where users can easily select multiple polygons to submit to Survey123 through Experience Builder. I understand Survey123 does not support multiple geometries, but I'm curious if someone could help me figure out a workaround.
The polygons (watersheds) will always be touching each other, so if there is a way to merge selected polygons into one polygon and then send that to Survey123, this would be the ideal solution. I know there is an edit widget, but I need the original polygons to stay as they are for other users, and I also need users to take the survey without signing in.
Another alternative might be to extract attributes (watershed numbers) in a list, then send that to Survey123 as a string for processing on the backend with a Python code.
Unfortunately, I don't know Experience Builder well enough to know if either of these workarounds is possible or how to do either one. I would appreciate any suggestions or advice!
Thanks!
- Haleigh
ZhifangWang
Hi @hsummers_scf ,
Survey123 supports "repeat question", in which you can collect multiple answers (including geometries) to a related layer for one survey response. That being said, I assume you are only interested in the combined geometry (e.g. overall area of interest), I don't see the repeat question can help your workflow.
Also, the Survey widget does not support combining multiple geometries.
Therefore, the alternative approach you mentioned could be a potential workaround: you can submit object IDs or global IDs of those selected features to the survey, and utilize a webhook in the behind to combine those geometries and update the geometry of the submitted record automatically.
hsummers_scf
Thanks for the advice. Do you know how to send a list of IDs from Expereince Builder to Survey123? I have tried doing this as a single line text or multiline text, but it only sends the ID of the feature that is selected first, not a list of the features. Any advice?
AnthonyJonesRSK
Hi @ZhifangWang,
I have a similar issue where I want the user to be able to select multiple items in a list and then the IDs from those selected items get passed on to a multi-select question in Survey123. I tried to see if I can do this via url parameters but can't get it to work and as Haleigh mentions below, when you select multiple items in a list only the first is passed to the survey. Are there any ways to achieve this functionality at present?
Thanks, Anthony
