Widget Controller - reroute without having an extra button window
135
a month ago
SaraJL
This might be a duh question - but I've been diving through the documentation and forums, and I'm a little stuck.
I'm using a widget controller buttons to try and re-route users back to a main map:
But there doesn't seem to be a straightforward setting to just automatically navigate back to the other page - if you click on the widget button, it always opens and extra window prompt with a button:
Does anyone know if a setting where the user could just click on the button (in this case, the house) and return to the previous page? Long story short, I don't want it to be a button that also opens to a window prompt with another button. Just click the house icon and return to the original page without an extra click.
Thank you!
JeffreyThompson2
MVP Frequent Contributor
That is how Buttons in a Widget Controller work. They pop out a panel which contains the Button. It's not a good design. It a common complaint, @Jianxia.  Here's an Idea to change it.
It is possible to replicate the look of a Widget Controller Button and stick it next to your Widget Controller or replace a Widget Controller with Button Widgets to simulate your desired functionality. Here is a Blog about how you can do that.
GIS Developer
City of Arlington, Texas
