Wanting to sync two maps in one map widget
2945
09-06-2024 06:44 AM
FaithBest
Hi All,
I am using version 1.15 Developer Edition.
I can add two maps to the same map widget and that's great, but how do you sync the map extents?
Right now, both maps work independently of each other, and I feel like that's not how it is supposed to work.
Any help would be greatly appreciated, as I cannot find the setting to sync the two maps.
Could it be because they have different coordinate systems?
Thanks in advance,
Faith
2 Solutions
JeffreyThompson2
MVP Frequent Contributor
To keep the extents of two maps in-sync:
  1. Add two Map Widgets to your layout and connect them to the webmaps.
  2. In Map Widget 1, go to the Action Tab > Message Tab > Add a Trigger > Extent Changes > Map 2 > Pan To.
  3. Do the same in Map Widget 2 with the target being Map Widget 1.
GIS Developer
City of Arlington, Texas
JeffreyThompson2
With two maps in the same widget, the maps should sync automatically.
The thumbnails for the maps are a static image and will not change, but clicking them should show the other map correctly panned.
If the maps are not syncing then the problem is likely the mismatched coordinate systems. Possibly separating them into two widgets as above will fix the issue.
GIS Developer
JeffreyThompson2
GIS Developer
FaithBest
Yes! That works great for two map widgets, but is there no way to do it in one map widget holding two maps?
JeffreyThompson2
GIS Developer
