use images from attachment table in image widgets
1251
02-18-2020 11:49 AM
GeomaticsPublisher
Is it possible to use attached imagery in a feature layer as a dynamic input to an image? I would like the image boxes in the list widget to automatically be populated from the attached imagery in the source feature layer it's connected to?
The only widget I can currently see that allows you to access the attached imagery is the Feature Info widget which has an attachments button however the imagery thumbnail is extremely small and not very useful,
thanks
phil
DavidMartinez
Currently, in the list widget, there has to be a field that contains the URL of the image. It does not query the attachments in the feature layer.  Is this what you're asking?
David
