Unable to view feature class data in an Experience Builder List Widget
1907
01-21-2022 01:45 PM
KenStocks
I am trying to use the Experience Builder List widget to display ArcFM switch feature class data.  I can add the fields using the Dynamic content as shown below, but data is not populating afterwards.
The same data from above is viewable in the same Enterprise Dashboard.
I am following along this video and expect to see my data to appear just after the 10:30 mark.  Any help would be appreciated.
Create custom web mapping applications in an intuitive, easy-to-use, what you see is what you get (WYSIWYG), wizard environment.
jcarlson
Can you go into your Data Source tab on the left-hand menu and check to see that your data layer is coming in correctly? You don't have any other widgets that would be filtering your data, do you?
- Josh Carlson
Kendall County GIS
KenStocks
Josh,
I can see the layer in the data source tab, identify individual point features in the map, and display attribute data.   The only 2 widgets used in the experience are Map and List.
KellySt__John
Was there a resolution to this?  We'll shortly be replacing some of our WebApp Builder Apps to Experience Builder, and often consume ArcFM feature class data.  It would be nice to know if there is an unknown hurdle before we go down that path.
