Is there a way to connect a Dashboard with a map within Experience builder?
887
10-03-2023 05:22 PM
EstebanBarbosa1
I was trying to include a print feature for a water utilities Dashboard I had just made that would print out all of the graphs and indicators for selected features. I had successfully added a map displaying the features and configured it to filter by size, material type, ownership, etc. However, I realized there is no option for a print feature/widget within Dashboard like there is for Experience builder. To get around this, I had made a new Experience with a web map containing the utilities feature layer and added a print widget. I then embedded the Dashboard within the Experience. I did try to add a Trigger Action by Record Selection Changes and Extent Changes using the Framework and set the Feature Layer as the Action Data. But this still doesnt cause the map to connect with the graphs and indicators within the embedded Dashboard and change to reflect map extents. Does anyone have a workaround for this?
