Templates associated to Survey 123 feature not listed for selection when add Report widget for Survey in Experience Builder
121
3 weeks ago
JoClarkeBega
I have associated a number of Templates with Survey feature from Survey 123 connect and staff are able to generate reports successfully in Survey 123 report. I am trying to configure Feature Report widget in Experience Builder, using results from a Select widget but the templates that are already uploaded in Survey 123 are not listed under select existing template and if I upload again from our network it creates duplicate template portal items.
When I have done this, I can get the resulting reports to generate - I am an Administrator of the portal, but general users are not able generate reports - they cannot "locate" the templates. I have read that need to be using the templates that are already associated with feature through Survey 123 but I do not have option to do this when configuring Feature report widget.
Has anyone else tried same workflow and solved this issue?
JoClarkeBega
I have discovered what the issue was. My results feature layer being used in the report widget was in a different folder to the Survey. Once I relocated it, the Survey templates were available to use in the Feature Report widget
