Switch on individual layers of a map with a button
23139
32
10-26-2021 05:14 AM
ksm-hh
Hello all,
I have loaded a web map with different layers into Experience Builder to create a WebApp. In this web app, individual layers of the web map should be able to be switched on and off with a button or a switch.
Is this possible and do you have any tips on how I can implement this?
Many greetings
CatherineHall678
Hi! I have been scouring (perhaps not thoroughly enough) the community with the same question, within the AGO Dashboard>> a "button" element that will allow a layer to turn on and off. I didn't see any solution other than utilizing ExpBuilder.
To no avail, I'd like to share my simple workaround w/in the dashboard. I hope this helps someone.
KristapsKaugurs
Nice idea!
It took me a while to figure out what you are talking about, but I got there 🙂
This looks a lot like my reverse filter method where layer is loaded and then filtered out. Does this also load all the layer data to the map straight away?
See, if I am working with large datasets, then layers that are switched off, dont take up any resources. Once you load everything in, the app starts to slow down.
My reverse filter method loads all data and hides it by filtering it away. However, it LOADS IT ALL to the memory and thus is very unusable with large datasets. Do selectors behave better?
KatieDawson23
The closest I think I have come to this is having multiple map widgets in a section and each view containing the specific combination of layers I need. This acts like bookmark, but to keep the map extents the same you use action triggers. So when the extent changes in one map, the zoom changes in the other maps. Name the view as desired (e.g. "View Property Data" etc.) then use the Views Navigator to change the layers. So when you click on each view the map layers change without it affecting the map extent.
