Showing image icons in pop-up conditionally based on field attributes.
1886
08-12-2024 04:37 PM
NigelGriffiths
Hello, I wish to replicate something along the lines of what is being done in this application, where you select a point feature on the map and at the bottom you will see icons based on whether a particular attribute is TRUE or FALSE. Rest Areas (nsw.gov.au)
The attribute table looks like so:
has_bbqFALSE
has_caravan_disposalFALSE
has_emergency_phonesFALSE
has_lightingTRUE
has_litter_binsTRUE
has_picnic_tableTRUE
has_playgroundFALSE
has_power_outletsFALSE
has_shelterFALSE
has_toiletsTRUE
is_accessibleTRUE
Is there a way this could be easily replicated in Experience Builder, using ArcGIS Pro, Web Map Viewer, or directly within Experience Builder in which it will ultimately be consumed.
GIS_Weasel
We had to use a monstrous hack to do something similar directly in Experience Builder, creating an expression to source an image from a webserver based on attribute values in the URL field.
However, yours looks like it could be done with by adding a simple Arcade expression into the popup config. Configure it in the Map/Scene Viewer:
var t =  $feature.COMMONNAME;
var v = "https://placebear.com/200/300";
return {
    type: 'fields',
    //title: '',
    //description : '',
    fieldInfos:  [{
          fieldName: "att1"  // fieldName should match the key in the attributes dictionary
          fieldName: "att2"  // fieldName should match the key in the attributes dictionary
          fieldName: "att3"  // fieldName should match the key in the attributes dictionary
    attributes : {att1 : t, att2 : "<img src=\"" + v + "\" />", att3 : 4}  // replace this dictionary with your own key-value pairs
I've tested and yes, the HTML element in the attribute object is rendered properly.
GIS_Weasel
return {
    type: 'fields',
    //title: '',
    //description : '',
    fieldInfos:  [{
NigelGriffiths
Thank you very much for your suggestion. I was able to achieve the desired result by having an arcade attribute expression for each field and image, then having a text element above the fields table that included the expression in HTML code.
Desired result below
Arcade expression used for each image
var checkvalue = $feature.has_toilets
var img_show = 'https://imageurl.com'
var img_blank = ''
iif(checkvalue=='TRUE',img_show,img_blank)
The following HTML code was placed into the text pop-up element
<img src="{expression/expr0}" width="50" border="0"><img src="{expression/expr1}" width="50" border="0"><img src="{expression/expr2}" width="50" border="0">
 I am unsure if your method is the better solution, as I have limited experience with Arcade so was unsure how exactly to implement it.
