Hello, I wish to replicate something along the lines of what is being done in this application, where you select a point feature on the map and at the bottom you will see icons based on whether a particular attribute is TRUE or FALSE. Rest Areas (nsw.gov.au)
The attribute table looks like so:
| has_bbq | FALSE |
| has_caravan_disposal | FALSE |
| has_emergency_phones | FALSE |
| has_lighting | TRUE |
| has_litter_bins | TRUE |
| has_picnic_table | TRUE |
| has_playground | FALSE |
| has_power_outlets | FALSE |
| has_shelter | FALSE |
| has_toilets | TRUE |
| is_accessible | TRUE |
Is there a way this could be easily replicated in Experience Builder, using ArcGIS Pro, Web Map Viewer, or directly within Experience Builder in which it will ultimately be consumed.
We had to use a monstrous hack to do something similar directly in Experience Builder, creating an expression to source an image from a webserver based on attribute values in the URL field.
However, yours looks like it could be done with by adding a simple Arcade expression into the popup config. Configure it in the Map/Scene Viewer:
var t = $feature.COMMONNAME;
var v = "https://placebear.com/200/300";
return {
type: 'fields',
//title: '',
//description : '',
fieldInfos: [{
fieldName: "att1" // fieldName should match the key in the attributes dictionary
fieldName: "att2" // fieldName should match the key in the attributes dictionary
fieldName: "att3" // fieldName should match the key in the attributes dictionary
attributes : {att1 : t, att2 : "<img src=\"" + v + "\" />", att3 : 4} // replace this dictionary with your own key-value pairs
I've tested and yes, the HTML element in the attribute object is rendered properly.
return {
type: 'fields',
//title: '',
//description : '',
fieldInfos: [{
Thank you very much for your suggestion. I was able to achieve the desired result by having an arcade attribute expression for each field and image, then having a text element above the fields table that included the expression in HTML code.
Desired result below
Arcade expression used for each image
var checkvalue = $feature.has_toilets
var img_show = 'https://imageurl.com'
var img_blank = ''
iif(checkvalue=='TRUE',img_show,img_blank)
The following HTML code was placed into the text pop-up element
<img src="{expression/expr0}" width="50" border="0"><img src="{expression/expr1}" width="50" border="0"><img src="{expression/expr2}" width="50" border="0">
I am unsure if your method is the better solution, as I have limited experience with Arcade so was unsure how exactly to implement it.
