Hi there,
I would like my chart to filter, select and zoom to selected features in the map. At the moment it selects and filters but does not zoom to the features.
This is how my chart actions are set up
And this is the map
Any pointers would be greatly appreciated thanks 🙂
Solved! Go to Solution.
I am hoping that @Jianxia may be able to provide the status on the ability to select a feature in an Experience Builder bar chart widget for example and then see the map pan and zoom on the selected feature.
Does ESRI have plans to address this known limitation dating back to 2022? A user should be able to select a bar on a bar chart and have the map pan and zoom to the location on the map. I will submit an enhancement request to check on the status of this important (2,360 views at the time of this post) functionality.
Hi all, does any one know if this enhancement has been added (ENH-000151058)? I am assuming it has not because I am also trying to zoom to features from my chart widget and am not finding an option to do so. Is there a way to look at the enhancement status or to get it associated with my Org? ENH-000151058
Hi @Jianxia, Are there plans to develop an enhancement in Experience Builder so that a user would be able to select a data series in bar chart widget, for example, and then the map would pan and zoom to that feature?
