Select Widget, Actions, View in table only shows 1000 records
936
01-13-2025 10:57 AM
JoseSanchez
Good afternoon
I am going a selection with Select Widget that returns 7000 records, and i would lie to see them in the Table widget. When I select Actions, View in table only shows 1000 records, it only shows 1000 records not 7000.
Is there a way to list all the records selected?
JoseSanchez
ZenMasterZeke
You can set a 'maximum record count' property in the table widget. However, the feature itself may have a limit on how many records it can return in one go. 7,000 records is a lot, and could slow performance down. You may want to set up filters.
