Resize image in Map Viewer/ExB popup
856
09-17-2024 11:27 AM
DanCopKac
I'm trying to create a link/button a user can click in the popup to generate a VCF (vCard) with data from the layer attributes, like:
data%0Atext/vcard;charset=UTF-8,{expression/expr4}
When I tried using Text content in the popup, it didn't work because it turns the link into
"#text/vcard;charset=UTF-8,{expression/expr4}"
which just brings the user back to the same page.
So I got creative and tried using the Image Content with this image:
And that works. I can set the link to
and Map Viewer nor ExB doesn't change it. Now when I click the image, which was made to look like a regular link, it downloads the VCF.
But the image is taking up too much space in the pop-up. The image itself is very short (height) and slim, but for some reason the space allocated to it is huge. It's pushing all of my other attributes down. I want the download button/link to just look like another line attribute in the pop up.
Maybe I'm an idiot, but I can't figure out how to control the image properties. How can I shrink the space taken up by the image and left justify it so it looks like any other line item?
Ke_Xu
by Esri Regular Contributor
Hi DanCopKac,
In Exb, it is not possible to modify the content of the Popup. How about asking this question on the ArcGIS Online board?
Ke
